No displays in output menu
josebelladonna
Post by josebelladonna »
Hi, I've just installed Resolume Arena 5 and been playing around with it. I've installed it into an early 2008 MacBook White (MacBook 4,1), and it runs ok. It's a very simple show I have to set up, with no layering, just the need to change videos smoothly with a keypress. I know Resolume is an overkill for this, but I do plan to do more complex things in the future and it'd be nice to already get the hang of it.
The problem is, I'm stuck at something really basic: the external monitor hooked up to the MacBook is not showing up in the outputs menu. There's only the "Disabled" option, with no way to uncheck it.
I am running OSX Lion 10.7.5, the monitor is connected via a mini display port to VGA adpater. The OS ercognizes the external monitor just fine, it's not mirrored and it's using its native resolution.
I know I am running old hardware, but this is the only notebook I have right now, and OSX 10.7 is supported.
¿Do you know what might be wrong?
Thank you very much for all your time, I have attached some screenshots:
Screen Shot 2017-08-09 at 17.18.25.png (134.14 KiB) Viewed 3005 times
Re: No displays in output menu
My guess is that Intel GMA graphic card is just too old. If you'd like, you can use the feedback tab to send us your log file so we can take a look.
Magic 8 ball says 'outlook not so good' though :/
drazkers
Post by drazkers »
Try installing resolume 4 maybe?
