No GRBW space color ?
Nolaz
Post by Nolaz »
Hello all,
I'have a GRBW led strip I would like to control with Resolume, but I can't find a "GRBW" choice in the drop down menu of the user fixture settings... only "RGBW", so of course the red and the green are inverted...
I find it weird that not all the possible configurations exist...
A solution please ?
Re: No GRBW space color ?
This color space is indeed not available. I've made a feature request for you.
Nolaz
Post by Nolaz »
Thank you Joris.
Do you know when the next release of Arena is planed ?
There is no date set. If your show depends on a GRBW color space, it's probably best to find a different software solution.
Nolaz
Post by Nolaz »
:cry: ok thank you !
what kind/brand is this led strip?
which driver/chip does it use?
If it's a controller with a phoenix connector, could you not just swap the cables in the phoenix connector to make it a RGBW fixture?
dinga wrote:could you not just swap the cables in the phoenix connector to make it a RGBW fixture?
exactly where I was trying to get :)
