New monitor
soren
New monitor
Post by soren »
Hi all,. I am thinking about getting a monitor for editing my photos, which do you recommend?
Thanks.
https://thedigitalcamera.net/best-monit ... otography/
Re: New monitor
IPS for photo and video editing imo.
I'm running a LG 31MU97
Wankti
Re: New monitor
Post by Wankti »
I use NEC PA322UHD 4K 32" screen. not cheap but it is the best in its class.
This is a 10Bit screen so I'd recommend upgrading your video card (I had GTX 1080 when I had a PC) or something with 6GB RAM to handle multiple desktops. Also to not suit those who make HTML websites or someone who uses programming languages for coding.YOu can find about it from this source
OrlandoRam
Re: New monitor
Post by OrlandoRam »
Wankti wrote: Wed Jul 11, 2018 14:49 I use Testo-Max and NEC PA322UHD 4K 32" screen. not cheap but it is the best in its class.
I believe Dell has some decent IPS models in a budget segment of the market. I'm not sure what the exact marks of the latest models are, but I'd suggest anyone looking for a decent IPS panel monitor look into those.
