When I choose 'interface' + 'preview' on my first display and enable second display (fullscreen or window), then there is absolutely no image on the two display !
Thanks for your help !
Problem with 2 displays
SiliconCarney
SiliconCarney
SiliconCarney
- digital:snot
SiliconCarney
No, result is the same with Indeo encoded file ! When I activate the second display, both are totally black...
And in the clip tray too !
Why, in the screenshot in the presentation of resolume (http://www.resolume.com/features/index.php), there is widescreen ? My trying version of Resolume 2.2 don't have this.
And where is the preview window that we can find in the oldest versions of Resolume (under the files list) ?
[Edite le 8-4-2005 par SiliconCarney]
- digital:snot
You will need to change your screen resolution from 1024 x 768 to 1280x1024 or similar. (widescreen lcds' are different)Originally posted by SiliconCarney
this will give you the additional controls available in the "widescreen" layout.
SiliconCarney
