some "only had some minutes to try"- Remarks to the new effects
movebandit
Post by movebandit »
Well done . Thanks for that huge Update. Nearly all my wet wishes came true.... (Mainly Persistent Clips !!!)
BUT: Here are some "only had some minutes to try"- Remarks to the new effects:
-Text Block and Animator: Spacing too less Parameter Range
-Slice Transform: Dropping Slice doesn´t work (or am i wrong, and cant´handle the new plugin ?)
-Reveal: when Clip trasnformation is in 100% Scale, Scaling of reveal is not correct
-Rings: Set Gap to 360 Deg to be able to blank rings
Re: Resolume Avenue & Arena 6 Beta Available Now!
Take a look at this video and hopefully that'll give you a sense of what you can do with it:
highstreetpictures
Re: some "only had some minutes to try"- Remarks to the new effects
Post by highstreetpictures »
hiya guys!
i've been looking for a way to change screens and thus switch slice arrangement in real time - using one projector.
for example - one screen multiple slices on a layer - fading between them - then fading to a screen where three slices are shown at the same time full opacity in a triptych - then back to the full screen fading between slices.
it was suggested slice transformation could help - as an effect dragged to a layer - with what i assume is each screen as an effect dragged to the same layer... but i can't get the screens to transition from to the next.
any thoughts would be very much welcomed. simon
Maybe this will answer your question:
highstreetpictures
i am going to have record my screen to show what i'm trying to accomplish - perhaps it's easier than i'm thinking - i keep coming up against the advanced output only allowing one screen live at a time - making the others virtual. i feel i should be able to transition from one screen (with its own layers and mapping) to the next within advanced output. that doesn't seem to work.
i tried dragging a screen with its own layers as an effect to a layer - but then the slices are wrong.
i'm going to upload a screen recording - i hope that will sort it out - and a big thank you for the suggestions so far. simon
Could you tell us more about the real world situation you're trying to deal with?
Is this a projection on an object that moves or changes?
