R6 - OSC Shortcuts
mfo
R6 - OSC Shortcuts
Post by mfo »
Hi
the new shortcuts window and all features coming with it are fantastic! Big leap forward.
However, one thing missing (and maybe its work in progress?):
* OSC remapping - can't change the addresses any longer? This feature was one of Resolume's main strengths, so it could easily be incorporated in bigger setups!
Re: R6 - OSC Shortcuts
You can.
Enter OSC shortcut mode,
create a new shortcut preset by opening the combobox and selecting New... on the top of the Shortcuts panel,
enter a name for your preset,
click on an item you want to map,
click OSC output checkbox in the shortcuts panel,
select Custom address in the combobox below the switch,
click on the address that appears to edit it below.
mfo
Post by mfo »
Ah right. cool!
Now I'm wondering: how can you control the scope? For the non-custom addresses you can change i.e. between "on this layer" and "for all layers", but when you choose "custom" these options are gone?!
