Epson projectors Tiling feature (multiple projectors from one super-resolution output?)
joedanger1
Post by joedanger1 »
I was perusing the manual for the epson projectors we have on order and I came across this interesting feature: https://files.support.epson.com/docid/c ... ainer.html
Where essentially using only the projector built-in software (in a networked environment), seemingly independent of the VGA Card or resolume's capabilities, you may tile up to 9 projectors into one large screen.
The questions then becomes:
1. Does this mean that 9 Epson projectors TILED together only needs ONE HDMI/DP OUTPUT of resolution (9 x (1920 x 1200)).
2. And therefore only a single signal cable is fed to the MASTER projector. The other 8 projectors will get their signal from the master projector via the network (or by magic).
If this is true, then it is mind-blowing because one GTX1080 can handle theoretically up to (4 x 9) or 36 Epson projectors without using other hardware.
Has anyone tried this feature in an epson projector (any Epson reps hanging around here)? It sounds too good to be true.
PS. This particular Epson projector also has built in edge blending feature so you can edge blend the 9 projectors by only using the internal menu of the projectors before firing up Resolume.
joedanger1
Re: Epson projectors Tiling feature (multiple projectors from one super-resolution output?)
It appears that I have misunderstood this feature. According to the Epson rep, it is either edge blending or tiling. One cannot edge-blend and then tile into one large display. It is indeed to good to be true.
Anyway when the projectors come I will test it out myself and update the forum.
