Win7 64bit, when trying to install it gets stuck in a loop at the point while trying to copy the sample .movs .
Fails and then confirmation window opens again and again.
Solution was to Run as Administrator, even though I am. It still took a couple attempts to install completely.
Ave Beta 6 install issue Win764bit
Re: Ave Beta 6 install issue Win764bit
Are you sure your user was administrator?
What did the prompt say exactly about the mov files?
I tried installing on windows 7, even turned UAC back on and the only prompt I got was when I launched the installer, to allow it to modify files.
Anyone else having this issue?
Both installs I used had win7 64 on an admin account without issues. UAC was off because of Ai tho. But the account was the only one on the machine.
Dirk Diggler
Correct, only 1 user, me. UAC turned off. Prompt install window would disappear, and then got stuck in the loop over and over.
