Input Device Benchmarks
Hey Guys,
I had some downtime today so I thought I would create a small benchmark thread for input devices.
This is being made to compare Resolume 5 with Resolume 6. I benchmarked everything on both versions so we can compare performance.
Here are the devices I tested with:
Black Magic Ultrastudio SDI
AJA U-Tap SDI
Magewell SDI 4K Plus
NDI (Direct PC to PC)
The 2 computers I used were:
2017 Razer Blade (GTX 1060), Running a single layer at 140+ fps
2015 HP crap i5 Laptop with integrated Intel HD GPU, Running a single layer at 33 fps
Both PC's had their screens AND composition set to 720p.
All the input devices were configured for 720p@60
I was coming out of my PC's HDMI port into a Black Magic HDMI to SDI Micro Converter for all of these tests.
Here are the results:
Resolume 5:
AJA U-Tap SDI - 7 Frame Delay
Black Magic Ultrastudio SDI - 4 Frame Delay
Magewell SDI 4K Plus - 4 Frame Delay
NDI - 22 Frame Delay
Resolume 6:
AJA U-Tap SDI - 4 Frame Delay
Black Magic Ultrastudio SDI - 4-6 Frame Delay
NDI - 7-10 Frame Delay
I didn't test with Spout as there really isn't that many applications developed for it as there is Syphon, And I don't use OSX anymore.
All of these tests were done in Arena, with no background applications running at the moment of testing.
What I would like to see, is some more benchmarks added to this thread.
Here are a few devices I had in mind:
Syphon/Spout
Datapath Input Devices
Black Magic Decklink Input Devices
Black Magic Mini Recorder
If anyone has some of these devices (or any other input devices you would like to add to the list), and has the time to do some benchmarks, I would love to see how everything is stacking up in version 6 from version 5.
I'm really impressed with the improved performance with the AJA U-Tap. Well done guys!
Warspite
Re: Input Device Benchmarks
Post by Warspite »
Is input from AJA smooth?
My AJA behaves like there is non constant fps with frames dropped. Blackmagic is smooth.
Also, your resultsare higher than mine, so this delay depends on system and cannot be compared directly.
On MacBook i have this numbers
Aja U-TAP gives me 4 to 5 frames delay (0.16-0.2 of a second). Taking photos i admit that i get 4 frames delay more often, so delay is around 0.17 of a second.
Blackmagic gives 1 to 2 frames of delay (0.04-0.08 s). Most of a time 2 frames, so delay is around 0.07 sec.
So, Blackmagic gives 2,25x times less delay.
Warspite
Post by Warspite »
Ok, your delay is measured at 60 fps. So when we convert to milliseconds, results are comparable, that is great.
Warspite
Post by Warspite »
How you measured delay from SDI input? We can consider that video-output from videocard has 0 delay, but i do not think this is correct for native SDI output on capture card or with help of some sort of converter/scaler.
Warspite
Post by Warspite »
Also, i have a question - slices in advanced output are rendered top to bottom or bottom to top. On some complex setups your get delay from this, and it is good to keep live input slices close to render start point.
This was done at 60fps, so 1 frame is 00:00:00:01 (Hr:Mn:Sc:Ms).
I had a computer with a Timecode Counter running and outputing via HDMI into a BMD Micro HDMI-SDI converter, into my Input Cards.
Both computers are side by side and I took pictures with my phone and counted the delay from computer to computer.
Pretty straight forward.
Resolume was setup with a single slice in ASS. Nothing to crazy, Again... This is a benchmark, I want to know what the basic setup results will produce, all the extra fanciness can be calculated later. But if it's going to add that much more of a strain on your system, knowing what cards work best when there isn't any strain should make your purchasing decision a no-brainier at that point :P :lol:
Dinga, what kind of network were you using when you did your NDI testing? Was it a dedicated 1G wired network?
Oaktown wrote:Dinga, what kind of network were you using when you did your NDI testing? Was it a dedicated 1G wired network?
It was a direct link from pc to pc via a cat6 cable. Gigabit connection on my Blade, I'm not sure about the NIC on my HP, I Just got a Blade back from tour, so I can try to re-do this from Blade to Blade in a week or so when things slow down.
If anyone else has the time and wants to try it out, that's kind of the point of this thread, so we can get everyone's input and updated benchmarks :)
Warspite
Post by Warspite »
Tested Blackmagic and Aja U-Tap with Resolume 6.
Source - Macbook HDMI Out at 720p50, receiver - X99 based Rack PC.
Built into resolume 5 test card with 25 fps timecode
Aja U-Tap - 1-2 frames delay at 25 fps (around 60ms).
Blackmagic Mini Recorder HDMI input - 2-3 frames delay at 25 fps (around 100ms).
Blackmagic Mini Recorder SDI input with Decimator HDMI to SDI converter - 2-3 frames delay at 25 fps (around 100ms). So Decimator SDI-HDMI converter does not add any latency.
Blackmagic Decklink Duo 2 SDI input with Decimator HDMI to SDI converter - 2 frames delay (around 80ms).
So Aja is now even better than Blackmagic. What a twist! Bravo Resolume Team!
But also Blackmagic is 1 frame behind to my previous tests. Just wander if this change is up to new version of Blackmagic Desktop Video Software or because of Resolume 6.
drazkers
Post by drazkers »
Warspite wrote:Tested Blackmagic and Aja U-Tap with Resolume 6.
May be slightly more accurate if those tests are done at 50 or 60 FPS. Gives a little more resolution in your ms, as i suspect both devices have less latency in ms.
