speed problem @ output monitor
jerico_
Post by jerico_ »
hi @ all
i have dramtic speedproblems at the oputput monitor.
the motions are not fluently it stocks don't make fun at all!
i have a pentium 4 with 1,8ghz 512kb
512 mb rams
nvidia geforce 4 -card 128mb
anyone an idea?
If you use the following method of setting the output window fullscreen you will not have the seed problems anymore.
Here it goes: Undock the output window by clicking 'Dual monitor'. Click 'configure' on the bottom of the output window and choose: Output -> Resolution: 320x240x16 -> Scale to: 640x480. Not click configure again and press 'fullscreen' (or press ALT+CTRL+ENTER or click the far right icon at the bottom of the output window)
This way the output window takes over the display and sets it to 640x480. And will result in much fatser playback results.
jerico_
Post by jerico_ »
yeah, speed is now o.k. thanks @bartholomeow but the quality sucks! other ideas?
yes do not set the stretch to resolution to 640x480 but to a higher resolution ...
kuba_
Post by kuba_ »
and here`s one magic combo :)
Ctrl+Alt+2
Ctrl+Alt+D
Ctrl+Alt+1
Ctrl+Alt+M
