Arena 6 and Chaser
gnetic
Arena 6 and Chaser
Post by gnetic » Sun Sep 24, 2017 21:47
Hi JORIS Has Arena 6 Beta been tested and working with your CHASER script.
I have upcoming visual performances for ESCAPE, and EDC Orland, it would def be a bit of relief to know b4 hand.
Have you or anyone else tested it yet to see if it's stable and working ?
Amzing update BTW, I was still really hoping for MIDI scrolling or shifting assignment for midi assigned clip triggers like you can do in Arkaos grand, and in Ableton live, but hopefully someday soon ?
Cheers.
Re: Arena 6 and Chaser
Post by Joris » Mon Sep 25, 2017 08:36
Chaser will be updated to be 64 bit compatible. I have the 64 bit versions on standby, ready to go.
I'm just waiting with a wide release until we sort out some unrelated kinks with the new FFGL implementation.
lovezhiqi123
Post by lovezhiqi123 » Sat Jan 06, 2018 17:42
Joris wrote:Chaser will be updated to be 64 bit compatible. I have the 64 bit versions on standby, ready to go.
Does chaser work on resolume 6 now?
Post by Joris » Sun Jan 07, 2018 12:45
Yup
