View Setup does not get saved
Babcom
Post by Babcom »
If I select the Show Layer transition Controls, or un check the Show Audio Controls - now save my composition. Next time I run my comp. All is reset.
Re: View Setup does not get saved
Could you upload your recentLayout.xml? you can find it in Documents/Resolume Arena 6/Preferences
Close resolume, make a backup of this file, then delete/rename the original then restart resolume to see if that fixes this for you.
The layout is not stored with the composition, and should be saved every time you make a change to the item selection in View menu.
Babcom
Post by Babcom »
Thanks for clearing that out :) I made all the steps you mentioned. But it did not help. I even changed the file in text edit, without any luck... Where do you want me to upload the file?
All the best.
you can attach it to a post here zipped.
Babcom
Post by Babcom »
Sure thing
recentLayout.xml.zip
(1.17 KiB) Downloaded 977 times
strange, it works for me fine with your file as well.
Could you check that when you change a setting in view menu, this recentLayout.xml gets updated?
it should get a new timestamp.
