I noticed any automation set to follow "clip position" get lost once I quit Resolume 6.
Is this a known bug?
Clip position Automation Bug Resolume 6
Re: Clip position Automation Bug Resolume 6
Have you saved the composition before quitting Resolume?
franciesko
Yes sure. When I re-open it it's saying "link unavailable".
dirtyjohn_lv
I can confirm this.
I have a series of 11 images beginning in column 11. Each clip is set to 5s and "Play Next Clip". The last clip is set to play the clip in column 11. Works fine until you reopen even after saving. I don't get any errors, it just stops on the last clip without continuing to previously selected clip. Selecting the clip in the auto pilot menu again works.
what's saying that?franciesko wrote:Yes sure. When I re-open it it's saying "link unavailable".
could you post a screenshot how your settings look before and after restart?
franciesko
Here the two screenshots.
- Attachments
- Capturenolink.PNG (31.62 KiB) Viewed 6444 times
- Capture.PNG (27.45 KiB) Viewed 6444 times
Thanks, created ticket #9736.
