Shaper and Circle effect not working in Resolume 6 beta
homing
Post by homing »
Anybody got problems running the two new effects , Shaper and circle, in the resolume 6 beta ?
They load up, all the parameters are there and tweakable, but no output of any shape .
The ring effect get a yellow X
Screen capture of the problem here :
https://www.facebook.com/groups/5854801 ... 614033277/
Running on windows 8.1
Re: Shaper and Circle effect not working in Resolume 6 beta
The circles effect needs an input, so as an effect clip you need to point the video router part of the clip it to a playing layer, or layers below. Should work if you drop it to layer 2 and play something in layer 1.
The shaper effect doesn't need an input, if it's not working that's probably a bug,
which video card do you have?
homing
Post by homing »
Running on windows 8.1 , OS is in french, the folder "program files" is called "programme" in windows french, could that be part of the problem ?
I have a Nvida Gforce970m.
Currently trying to un-install, and re-install to see if it works
homing wrote: the folder "program files" is called "programme" in windows french, could that be part of the problem ?
I don't think so, if other effects work.
Could you send us log file, via the feedback tab in preferences, and refer ticket #9699?
homing
Post by homing »
log file sent via feedback
homing
Post by homing »
The new checkerboard and text generators does work
homing wrote:The new checkerboard and text generators does work
Could you also check the Rings source?
homing
Post by homing »
Bug still not resolved with Resolume 6.0.0
