R6 activat layer bug?
lovezhiqi123
Post by lovezhiqi123 »
Re: R6 activat layer bug?
What is that you are trying to show?
lovezhiqi123
Zoltán wrote:What is that you are trying to show?
Resolume 6 activat layer must click on layer name
Resolume 5 can activat layer on clip area
lovezhiqi123
It does work as expected when a clip is loaded in the layer.
lovezhiqi123
Oaktown wrote:It does work as expected when a clip is loaded in the layer.
I don't mean it..
R6 select layer 1,2,3 must click on layer name!
R5 can select layer on Image
Yes, that's because you don't have any clips loaded in these layers and the behavior has changed.
Greenfielt
Post by Greenfielt »
I did noticed this "problem" too. Well it's not really a problem ;)
It's much easier to select the layer like @lovezhiqi123 described (like it was in R5).
Now you have to click specific on the Layer title, which is much smaller...
Is there a possibility to bring it back in R6?
