External FFT issue in R6
skydeck
Post by skydeck »
I am having trouble getting an external audio signal into R6 for FFT.
I select a "audio input device" in the preferences, eg. soundflower, or builtin-audio-input, then for "external fft input" I can choose Input1, Input2 or no input. None of the settings result in a signal on the resolume fft, though.
In R4 there used to be just on dropdown for 'external fft input' were all devices with there inputs are listed, eg. "soundflower input1&2" . R4 works fine with the same audio setup I am using.
Am I missing something, or is this an issue on the beta?
Greetz.
Re: External FFT issue in R6
In Resolume 6 you can use only one device for all inputs.
Are you running Avenue?
Avenue beta3 has a bug where FFT inputs don't work, will be fixed in the next release.
skydeck
Post by skydeck »
Ah yes, thanks, that explains.
Am using Avenue, and feared it might be a bug. I'll wait for the next release, then.
...or are you saying that Arena doesn't have this bug?
skydeck wrote:Ah yes, thanks, that explains.
In the Arena beta3 the fft input works fine.
