Bypassed Group as Input Source for Slice
karlskene
Post by karlskene »
I'm trying to bypass a group from the composition and select that group as the input source for a slice. I've unchecked "input bypass/solo" but it's not showing up in the output transformation window. It only shows up if I turn off bypass.
I do the same thing with layers and it works.
Is this not possible with groups or is this a bug?
Re: Bypassed Group as Input Source for Slice
Thanks, it's a bug.
Will be fixed in the next release.
