I am having issues installing R6B3 on my 2012 MacBook Pro Retina running OSX 10.7.5.
About 1 second before the installer says that the installation is completed the crash notification appears. (attached a screen shot of this) The program does appear in my applications but also crashes when I try to launch it. No Resolume 6 folders have been created in My Documents.
What I've tried:
Restarting, Reinstalling, Re-downloading and trying to install again both Beta 2 and 3 (both of these install files work fine on my Mac running OSX 10.11.6)
I have confirmed that Security is allowing 3rd party apps to be installed.
Also tried going to the installer directly to initiate the install but still no luck.
Does Resolume 6 still work on OSX 10.7.5? I know it's getting on in years but this Mac ran R4 and then R5 really, really well for the last 5 years, hoping I can keep using it without changing the OS.
I have also attached copies of the Problem Reports from both the install crash and the attempted launch crash.
Resolume 6 Beta Crashes on Install
- Attachments
- Resolume 6 crash info.zip
- (479.67 KiB) Downloaded 404 times
Re: Resolume 6 Beta Crashes on Install
I have to ask: Why are you still using 10.7.5?
Resolume 6 needs 10.9 or better.
The sole purpose of the laptop is to run Resolume and it's always run really well as it came out of the box. Updates would come out and i just kept thinking if it ain't broke......Oaktown wrote:I have to ask: Why are you still using 10.7.5?
I'm definitely fixing it now though!
