R6 crashes when you want to add a new plugin directory (both FFGL or VST plugin)
thanks
R6 bug : crashes when try to add a new plugin directory
Re: R6 bug : crashes when try to add a new plugin directory
It's one of the plugins causing the crash, it will be the last entry in your log file.
Resolume 6 is 64bit now, so make sure you have only 64 bit plugins to load.
If you upload your log file and the plugin we can take a look at them.
Thank you but it crashes when I just hit the + button.
ok, please describe your system, which resolume 6 beta do you have, and also your log file would be of help.inzieye wrote:Thank you but it crashes when I just hit the + button.
Can you open compositions from Composition menu - Open file dialog?
I'm on macbook pro Retina 15 inch mid-2014 with OS X 10.10.5. with R6 beta 3.
And it crashes too when I ty to open composition from Composition Menu.
- Attachments
- Resolume Arena 6 log.txt.zip
- (4.92 KiB) Downloaded 665 times
Does the error reporter appear on the next launch?
If so, please send in the error reports, and please include the ticket number #9918 in the crash desription.
If not, does osx notify you that resolume has crashed?
OsX notify that Resolume has crashed and the error reporter appear but it crashes when I want to send report.
And it crashes to when I try to copy details report.
What can I do to help you?
When you get osx's error report notification, if you click on the notification, you get a dialog opened.
there on the bottom left you see a show details button.
Click it an you get a text display of the error report, which you can copy and paste into a new text file.
You can attach that text file zipped here to a post.
Here it is!
- Attachments
- R6 #9918.rtf.zip
- (25.3 KiB) Downloaded 690 times
Thanks, we'll look into it.
