R6b3 Clip Monitor bug
dirtyjohn_lv
Post by dirtyjohn_lv »
If you select 1 clip with the clip monitor showing, then select multiple clips the monitor hides part of the controls.
clip monitor bug.png (24.12 KiB) Viewed 5852 times
Re: R6b3 Clip Monitor bug
I can't recreate, could you save the layout and upload the preset file?
mygeneration
Post by mygeneration »
I can recreate this issue.
Depending on what layer is selected first, I also get a .png file flip on the X&Y axis.
Sending feedback Log File and video.
dirtyjohn_lv
Layout attached
Panels On Left.zip
(1.21 KiB) Downloaded 514 times
