Particles effect is missing in R6
docoptic
Post by docoptic »
Are there any plans to bring the Particles effect back?
Re: Particles effect is missing in R6
Yes, it's on the way.
edwin
Post by edwin »
Hmm, i wasn't planning to bring it back actually.
There is a couple of effects i believe are too old and not worth putting time in porting them to v6.
I rather spend time on building new effects, so i you have ideas for new effects, you are welcome to share them here.
btw. any specific reason why you would like to see the Particles effect in v6?
cvanhoose
Post by cvanhoose »
edwin wrote:Hmm, i wasn't planning to bring it back actually.
I would love for the Plexus plugin to work. Any plans on this one? It is from the Plexus footage pack,
docoptic
Post by docoptic »
We created a bunch of generative clips using the Particles effects, and unfortunately they don't work anymore in V6 after importing the composition. Which is why I was wondering if it was going to make it back. It would be cool if you could implement Particle System with similar parameters as the original "Particles" effect.
Is it safe to assuming the "Pixels in Space" effect will not be converted either? Cheers.
cvanhoose
Post by cvanhoose »
+1 for Pixels in Space.
mygeneration
Post by mygeneration »
+1 Pixels in Space
mygeneration
+1 Particles
edwin
Post by edwin »
I will have a look at the Particles effect, i think i can convert it properly and maybe even improve on it. I think the quality of the particles in v5 is so so.
edwin
Post by edwin »
Sorry guys, but the Pixels in Space won't make it to v6.
