V-Sync
rawdesigns
V-Sync
Post by rawdesigns »
How do you guys not get screen tearing with V-sync disabled? If I have V-sync on I don't get any tearing but my fps drop from 120 to 20ish. If I have V-sync off I get excellent fps 120 but my screen tears very badly when fast moving clips or strobe effects are active. Its like you cant have best of both worlds :(
drazkers
Re: V-Sync
Post by drazkers »
You wouldn't by chance have windows classic instead of aero would you?
DHoude
Re: V-Sync
Post by DHoude »
Windows Fall Creators update & Vsync locks me in at 30 fps now. I use to be capped at 60 fps on the 1703 Creators update from earlier this year.
140 fps without Vsync. Windows seems to be going backwards with every Win 10 update.
joshuadmello
Re: V-Sync
Post by joshuadmello »
Same problems here.
Any solutions?
joshuadmello
Re: V-Sync
Just installed the fall creators edition and rolled back my Nvidia drivers to 385.69.
FPS is back to 60.
It seemed like it was an Nvidia driver issue more than anything else.
Im on the Razer Blade GTX 1060.
joshuadmello
Re: V-Sync
Forgot to add -
I was still getting screen tearing after the update. Then I turned V sync on and its good to go.
rawdesigns
Re: V-Sync
joshuadmello wrote:Forgot to add -
with V sync on do you still get decent FPS?
rawdesigns
Re: V-Sync
joshuadmello wrote:Just installed the fall creators edition and rolled back my Nvidia drivers to 385.69.
is the fall creators update working? i had major issues with gpu and the update.
viewtopic.php?f=12&t=15105&p=63533&hili ... ors#p63533
joshuadmello
Re: V-Sync
Yep.
With V-Sync on + Fall creators update + 385.69 Drivers I'm getting a solid 60FPS constant. No screen tearing on strobes.
Even with 2 outputs through USB C to DP 60 FPS.
rawdesigns
Re: V-Sync
Yep.
I'll give it a go after I do a system backup! thanks!
