Low memory warning/recording not working.
diedraaitafeljafel
Post by diedraaitafeljafel »
Hello.
When recording in Resolume Arena 5.1.4 it only records for about 10 seconds after which it stops the recording and displays "LOW MEMORY!!" in the bottom left hand corner.
MSI GT73VR
Intel Skylake i7 6700
32G DDR4 RAM
GTX 1080
Windows 10
Any advice would be appreciated.
Re: Low memory warning/recording not working.
Resolume 5 is 32 bit, so you run out of memory while recording quite fast.
Resolume tries to write the recording to disk while the recording runs but that is not always fast enough so the memory can be used up.
It will depend on the composition resolution how fast the recording fills the memory, lower resolution should give you more recording time.
