R6 Custom prefs/comps/shortcuts folder location
mfo
Post by mfo »
for back-up, versioning and sometimes even sharing I like to store more Resolume preferences, compositions and shortcuts in the cloud. So far this is an arduous task done by hand. It would be great if could give Resolume a custom location for this folder block.
Re: R6 Custom prefs/comps/shortcuts folder location
I use symlinks to do such a thing.
mfo
Post by mfo »
I tried. This doesn't work under Windows, unfortunately. Thus my request still stands. Pleeeeaaaaaassse^^
drazkers
Post by drazkers »
The resolume guys seem to have a pretty set folder scheme that seems to be part of their design philosophy. I bet your gonna have a lot of trouble getting this request. But I could be way out to lunch here, just a gut feeling.
I use allways sync its free, super powerful, works on windows and was suggested to me by super nerd idol Keith Lostracco. I use it to sync to a Dropbox folder. It even does versioning.
https://allwaysync.com
mfo
Post by mfo »
Nice tips, thanks.
p.s. I don't mean to change Resolume's prefs folder structure, only change the place where it is saved.
