Resolume R6 Beta 3 will not open.
warpnote
Post by warpnote »
Step 1
Connect projector via hdmi 1080p
Step 2
Connect another monitor via minidisplay port
(I am using this one -> https://www.packedpixels.com/products/packed-pixels)
Step 3
Start Resolume R6 Beta3
Result
Resolume hangs, fails to launch. :?
Expected Result
Resolume 6 should launch, just like Resolume 5. 8-)
Workaround
Connect video-outputs after Resolume is launched. :geek:
Hardware setup
Windows 10 Pro, intel i7-7700 4.2HGHz, GFX1070 (PC Specialist Octane III), + the mentioned projector & portable screen.
Also using a APC 40mkII and Magewell hdmi+>usb input, but don't think those will affect the situation?
WarpNote - Warp Visuals
Re: Resolume R6 Beta 3 will not open.
Maybe the log file shows something, could you upload it please?
warpnote wrote:Also using a APC 40mkII and Magewell hdmi+>usb input, but don't think those will affect the situation?
if you get the hang on launch without them connected, they don't affect it.
warpnote
Post by warpnote »
I could upload the log, but for some reason, the site will not let med attach the file?
(Tried both mac and pc upload, strange stuff indeed)
Also, I dont get this error using the final release version 8-)
Edit: once I zipped the file, it would actually upload :D
Resolume Arena 6 log.txt.zip
(7.46 KiB) Downloaded 442 times
warpnote wrote:Also, I dont get this error using the final release version 8-)
Great, it's fixed then.
warpnote
Post by warpnote »
Yep, happy camper so far.
Will there be any videos explaining the new features for lazy people like me,
or is the manual my best bet? (I did buy the training videos some time back...)
Thanks for getting back to me Zoltan!
