Opening R5 comps in R6
VJ EyeSauce
Post by VJ EyeSauce »
Perhaps I'm missing something.
Does R6 support older comps?
I've bought a few vj packs from DocOptic (I believe you've partnered with them on your tutorial videos) that are Generative visuals. They won't load.
Also, I can't seem to have clips scale or change opacity via sound.
Hopefully, I'm just missing a step somewhere along the way!
Thank you!
drazkers
Re: Resolume Avenue & Arena 6.0.0 Released!
Post by drazkers »
VJ EyeSauce wrote:Perhaps I'm missing something.
Thank you!
Old comps will load but with the move to 64 bit a lot of effects didn't get ported. In the closed beta doc optic talked about how a lot of his packs don't work during release.
Re: Opening R5 comps in R6
So far only Particles, Snow and Sparkles have not been ported.
They didn't work during beta, and Edwin has been using them to test the conversion. They work on the release.
In general, your old R5 comps should just open fine now. If you have an R5 composition that does not open using the 6.0.0 release version, we'd love to get our hands on it.
docoptic
Post by docoptic »
Pixels in Space has also not been ported. Unfortunately a lot of our generative clips were created with these legacy effects, so we recommend only using them in R4/5.
This is true. You can now open our generative compositions in R6, but compatibility isn't 100%. Some of the interface/dashboard changes have also affected how they work. If the older effects do get ported, we'll definitely consider working on releasing an update for R6.
pfelberg
Post by pfelberg »
Updated two different systems with R6 rev. 60521, one notebook, one desktop, one running win 8.1 and the other win 10.
I am still unable to load R5 compositions. Zero decks.
pfelberg
Post by pfelberg »
Examples sent by e-mail.
Thank you!
pfelberg
Post by pfelberg »
Solved!!
Instead of copying R5 compositions to the R6 documents/compositions/ directory, just use the menu Composition/Open... from inside Resolume.
Thanks Daniel.
VJ EyeSauce wrote: Also, I can't seem to have clips scale or change opacity via sound
how are you trying to do this?
Godzil
Post by Godzil »
Joris wrote: Tue Nov 07, 2017 21:37
any news about Particles effect? i don't see it in R6.
