R6 : crossfader doesn’t work with BPM anymore?
inzieye
Post by inzieye »
Did I miss something in R6? It seems that crossfader speed is not managed by BPM.
And do you think il will be possible, in the future, to have the possibility to control fading duration (with seconds and why not minutes..)? (Layer transition, not only crossfader ;-))
Actually I need Vezer for that and only that.
Thank you
Re: R6 : crossfader doesn’t work with BPM anymore?
inzieye wrote:Hi,
Thanks for reporting this, I created a ticket (#10125).
inzieye wrote:And do you think il will be possible, in the future, to have the possibility to control fading duration (with seconds and why not minutes..)? (Layer transition, not only crossfader )
Many things are possible. The features bucket has a lot of ideas for new features, one of them is regarding longer transition times.
When and if these ideas will be implemented, has not been decided yet.
inzieye
Post by inzieye »
You're welcome.
And thanks for the infos about my request.
For Resolume users who need this flexibility, you can use Vezér (not expensive awesome tool) when you want to adjust time length of any parameter in Resolume. Very useful when you work for theater or danse for exemple.
https://imimot.com/vezer/
