*.mov
tobé_
Post by tobé_ »
My *.mov files aren´t workin in resolume :(
when i load a mov file into a channel it only shows a white screen?
any ideas why?
btw. great program i am only testing but maybe i purchase it..
yes streaming quicktimes do not work in resolume, we are looking into this.
We recommend using .avi files rendered with the cinepak codec @ 100% quality with every frame rendered as a keyframe.
See our manual for more info about getting the best playback results.
tobé_
Post by tobé_ »
thx!!
com.fused_
Post by com.fused_ »
you can always export an avi from a mov file in Quicktime
no extra prog required
norm_
Post by norm_ »
.mov exported with the cinepak Codec or any Codec supported by the MediaPlayer will alos work, a bit slower but it works on mine ..
