Few bugs Arena 6 ?
madido
Few bugs Arena 6 ?
Post by madido »
Hello,
probably it's because I've just start to scratch the surface with Arena 6, but there are some things I would ask about;
- If I delay some screen in advanced output, video signal is OK, but controls (for example master of the composition have strange behaviour.
- if I change timeline settings on a clip (loop direction etc) and I switch to SMPTE, when I come back to timeline parameters are resetted and the clip continue play even if is set to play from the start
- How can I enable NDI inputs? I cannot find it in sources
- It would be nice if Text Animator source and effect could share the presets
Thank you
Stefano
Re: Few bugs Arena 6 ?
Thanks for reporting these,
madido wrote:Hello,
Could you elaborate on this, what do you mean by strange behavior exactly?
Setting the clip transport discards the old setting of the clip in R6, this behaves differently than R5, I'll create a ticket. #10160
NDI sources will show up on the bottom of the list of the Sources panel once they are available.
Assuming your firewall is set correctly (not filtering NDI and MDNS),
You can then drag and drop them to the composition.
The preset file xml-s are different structure for effects and sources, so I'm not sure if that's possible.
madido
Post by madido »
For example if I lower the master, brightness is different in delayed outputs. It's ok in advanced preview, but not in output signals.
Thanks, this will be fixed in an upcoming release. (ticket #9901)
Kadete
Post by Kadete »
NDI stop showing on my sources :( what could happen? already rebooted.
Can detect my BlackMagic, but no NDI source.
check your firewall settings
Kadete
Post by Kadete »
Oaktown wrote:check your firewall settings
First thing that i did. i turn off both windows defender + firewall to check if was that.
Still no luck. I Had today but then resolume crashed trying to connect blackmagic. When i restarted NDI was missing.
joshuadmello
Post by joshuadmello »
Even I've had my NDI sources vanish after 6.0.2 update.
Solutions?
joshuadmello wrote:Even I've had my NDI sources vanish after 6.0.2 update.
Solutions?
mac or windows?
joshuadmello
Solutions?
mac or windows?
Windows.
I had to roll back to 6.0.0 to have them appear again. Going to do another test with 6.0.2 today.
