Madmapper into resolume
blabberbytes
How do I get madmapper into resolume?
blabberbytes
Re: Madmapper into resolume
Lol, I'm able to get resolume into madmapper but for some reason, i can't figure out how to get madmapper into resolume. Usually there's an icon under sources in resolume. In my older version of madmapper there was but, when i upgraded to 3, that option is missing.
The option is still available under [Projectors] and you need to [Publish to Syphon] any output you need to make available.
blabberbytes
Hmm, I did that but it still doesnt show up in resolume.
blabberbytes
Weird I did that and there is no Syphon Server madmapper showing up. I'm on resolume 5. I'll upgrade to 6 when I get can and try again.
I tested with 5.1.4 and picked up the stream no problem.
Can you check with Syphon Simple Client (see attachment) to make the stream is available?
Also check with Syphon Simple Server (see attachment) to make sure you can pick up that stream in Arena.
- Attachments
- Simple Server.zip
- (490.8 KiB) Downloaded 574 times
- Simple Client.zip
- (365.79 KiB) Downloaded 598 times
