SMPTE offset and midi shortcut bugs Arena 6
madido
Post by madido »
Hello,
if I set a timecode offset of a clip and I switch to timeline, if I save the project in timeline mode and close Arena, next time I open the composition the offset is resetted to 0.
If I save with clip in smpte mode the offset is OK
If I assign a midi shortcut to a column trigger inside a group it's not saved with project
Thank you
Stefano
Re: SMPTE offset and midi shortcut bugs Arena 6
madido wrote:Hello,
They also reset when you switch decks with the clips in timeline.
I created a ticket. #10215
Only if you set the target to This Group Column right?
I created a ticket #10216
Thanks for reporting these!
