Arena 6 support Spout~! solved~!!!
lovezhiqi123
Post by lovezhiqi123 »
I drop SpoutReceiver2.dll in Resolume VFX, I can't find Spout sources in the “Sources” tab.
Why? Does arena 6 not support spout?
Re: Arena 6 doesn‘t support Spout!!!
You don't need external plugins or dll-s to have Spout input and output in Resolume.
Your log file may say otherwise, but I think actually your dll might be breaking the feature.
BTW, do the spout examples work on your system? Integrated GPU-s might not support Spout at all.
My Razer Blade is running Notch via Spout as I am typing this right now ;)
lovezhiqi123
Zoltán wrote:You don't need external plugins or dll-s to have Spout input and output in Resolume.
Where is arena 6 Spout input?
I find arena 6 spout output,But I don't find spout input...
I run Spout demo,It works!
Re: Arena 6 doesn‘t support Spout???
You should find the Spout sources in the Sources panel when they are available.
lovezhiqi123
Zoltán wrote:You should find the Spout sources in the Sources panel when they are available.
What are your machine's specs?
Two things:
1) Have you tried turning the Output>Composition output sharing>Texture sharing (Spout) on to see if you get the Spout Server>Arena - Composition under sources?
2) After you enable Texture sharing, try to pickup the Arena - Composition stream in a Spout receiver to make sure it's not a firewall issue.
lovezhiqi123
Re: Arena 6 support Spout~! solved~!!!
Zoltán wrote:What are your machine's specs?
It works!
I have to run spout first, Then I can find spout in sources~!
Thanks a lot!!!
