APC40 mkII update on knobs problem
Tomi Ka
Post by Tomi Ka »
Hi, I have assigned knobs to control an opacity of a layer effects. When I switch between layers the knob's lights did not update.
Example:
-LAYER1 has assigned knob (1/CC48) to control OPACITY of a COLORIZE effect. I set OPACITY to 50%, the lights on the knob are halfway light up as expected.
-Then I switch to LAYER2 which has ths same effect set up to 0% but the knob on midi controller still shows 50% opacity. It updates only after I changed the value a little bit.
I didn't have this problem on Resolume5, even after opening a new composition all controllers were properly updated on previous version. Is this a bug or em I doing something wrong?
I am using Resolume Arena 6.0.1
Thanks a lot!!
Re: APC40 mkII update on knobs problem
Thank you for reporting this, this is a bug,
it will be fixed in the next release.
