Upgrade Question v4 to v6
Djtwok
Post by Djtwok »
Will the videos and midi mapping’s from v4 be imported automatic when upgrading ?
Macbook pro 13inch mid 2012
www.Soundcloud.com/djtwok
Re: Upgrade Question v4 to v6
The compositions you use under 4, will have to be opened via the Composition menu - Open file dialog, and then saved to have them stored in the new format, Resolume 6 uses, copying to the Resolume 6 won't work.
As the midi shortcut system has changed in a fundamental way too, you'll have to remap your midi shortcuts in Resolume 6.
