Controlling R6 with OSC sent from Ableton Live or Bitwig
p8guitar
Post by p8guitar »
I'm looking for the best way to control Resolume 6 with OSC messages sent from Ableton Live or Bitwig.
I'd like to launch clips, control opacity, effects parameters, etc.
The Livegrabber Max for Live devices do a good job for this in Ableton Live. You can control Opacity and effects parameters with the voidgrabber device and launch clips with the singlenotegrabber device.
Do you know any alternatives?
I tried the OOEEVV Abl-Resolume plug, but couldn't get it working. I think it was written for Resolume 5, and Resolume 6 uses a different synthax of OSC messages.
Is it possible to send OSC messages from Bitwig to Resolume?
Re: Controlling R6 with OSC sent from Ableton Live or Bitwig
p8guitar wrote:I'm looking for the best way to control Resolume 6 with OSC messages sent from Ableton Live or Bitwig.
with Ableton: viewtopic.php?f=12&t=15091
If you can set the OSC message address and value then probably.
Denys
Post by Denys »
May this is gonna help you. Is for Resolume6.
http://ooeevv.com/webwp/controlling-res ... c-v-1-6-1/
Give me your feedback.
If you are a max for live user you'll understand all patches, if not, may be I can help you.
Cheers from Barcelona.
