Hello everyone,
I'm not experienced in Resolume. May anyone say me is it possible to send MIDI note from Resolume to GrandMA2?
I want that Resolume triggers MA. Is it possible somehow?
Thanks in advance.
GM
MIDI Output
Re: MIDI Output
Yes but you need to do it via Artnet not midi. I've triggered Macro's this way.GregoryMatveev wrote:Hello everyone,
Thanks in advance.
GM
GregoryMatveev
Re: MIDI Output
May you describe how you do it, please and what hardware it requires?
THX IN ADVANCE!
Gregory
THX IN ADVANCE!
Gregory
Re: MIDI Output
Artnet merge is the easiest. You just need a cat5 cable.GregoryMatveev wrote:May you describe how you do it, please and what hardware it requires?
THX IN ADVANCE!
Gregory
What are you trying to do?
Technically you could use the midi out of resolume into a USB to midi cable and then remote input via midi. But that's a long way about.
If it's the ma on pc you could rtp midi and use remote input with rtp midi as the source.
But you'll need bomes if you want to convert cc to midi notes(MA only supports notes not CC)
VJ_Lazershaft
Re: MIDI Output
If you are using an Avo desk you cannot do artnet input (INTO the desk, Resolume handles IN+OUT just fine) only SACN, which resolume does not yet do, but a USB>MIDI cable works just fine
