CTRL & ‘effect shortcut' to assign an effect
sblurg
Post by sblurg »
in the manual it says :
You can assign an effect to a channel (...) press CTRL & ‘effect shortcut' to assign an effect to the active channel. This works like a toggle so press it again and the effect is removed.
it doesn't work for me ?
works just fine here, what effect did you assign the keyboard shortcut to? does it trigger normally (in one of the global effect slots) when you press the shortcut?
sblurg
Post by sblurg »
OK my bad, I thought "effect shortcut" meant the effects names in the effect browser. Got it working now? Thanks bart
Ruud
Post by Ruud »
hmmm nice :)
I'm using a 2nd USB keyboard on my laptop device to have a 2nd person controller,
are there any ways to control effect parameters by keyboard-control?
cheers
sblurg
Post by sblurg »
you mean a USB keyboard that doesn't have controlers ?
you could probably go through MIDI OX and transform the velocity of your midi notes into controler values but it's not as precise as a controler of course
Anonymous
Post by Anonymous »
Originally posted by Ruud
hmmm nice :)
cheers
You have to buy a MIDI controller (Oxigen 8 is cheap enough but it has only 8+2 usable potenciometer) and connect it via USB or game-port. You can adjust the parameters very quick and very comfortable. Keep workin'
Cheers
