Show test card and virtual screen
elgarf
Post by elgarf »
When slice input is virtual screen, and "Show Test Card" option is active, slice still take image from composition.
Re: Show test card and virtual screen
I'm not experiencing this in 6.02.
Do you have any slice routing on, or is this on a simple 1 slice set to comp output?
elgarf
Post by elgarf »
1 slice, two screens
Screen 1
Slice 1 /Input source: Screen 2/
Screen 2
Slice 1 /Input source: Composition/, transformed in output
Empty composition.
With Show Test Card I see image from composition (not transformed).
Same on 601&602, win&mac.
I understand now! The test card is not being mapped as per your screen 2 slice 1 mapping when you visualize in screen 1, correct?
I think if you want to use the test card that way you have to take a snapshot of the test card and use it as a clip.
elgarf
Post by elgarf »
Yes, I'm just using another test images.
But that's not expected behavior, because I want to see transformed test card on Input of Screen 1, like it was in R5.
Since virtual screens didn't work in 5.1.4, I went back to 5.1.3 and now I understand what you mean.
