Output Seperate Layer Audio?
IanR_AV
Post by IanR_AV »
Ive got a client who wants to play 4 videos at the same time with each audio going through a seperate PA. Is there a way of outputting audio from each layer?
Re: Output Seperate Layer Audio?
IanR_AV wrote:Ive got a client who wants to play 4 videos at the same time with each audio going through a seperate PA. Is there a way of outputting audio from each layer?
Currently this is not possible in Resolume.
What I personally use in projects like this, is I sync up a Ableton live via midi with Resolume. I send a note to Resolume from Ableton to trigger columns.
You can use any other DAW, that plays audio to a multi channel sound card and can output midi.
IanR_AV
Post by IanR_AV »
Awesome thanks for the quick response.
Client has decided to use a D3 instead :(
