Arena 6 crash when open same composition
pette
Post by pette »
maybe it is an unusual operation.
I was setup a composition, I made a mistake so I try to open the same composition from the menu
Composition > Open Recent
select the composition already load > Block Arena 6
Freeze computer.
Sometimes it log out the user.
Re: Arena 6 crash when open same composition
does this composition have the file you mention in viewtopic.php?f=12&t=15331 ?
pette
Post by pette »
at now I have replaced the file with working version.
So I try to create a simple new composition with 30 files , video in motion-jpg and it freeze and crash
thanks
were you able to send the crash report via the reporter dialog?
pette
Post by pette »
it doesn't crash... it freeze Arena and never works, so I have to force exit and it freeze the computer.
thanks
please attach this composition, so we can take a look.
also the process sample I mentioned in your other post could be helpful in viewtopic.php?f=12&t=15328
pette
Post by pette »
it's a quickly composition on the fly
test.avc.zip
(4.29 KiB) Downloaded 433 times
pette
Post by pette »
If I open test.avc > ok
now I open example.avc (default composition) > ok
now I open test.avc > block the R6
thanks
I tried the composition you attached.
Copied it to my compositions folder, started Resolume, Opened the file via Composition-Open menu.
Opened the example composition from recents.
Opened test.avc from recents, composition loaded fine.
Of course I don't have the media,
so please rename the folder you have the media stored that's in this composition with Resolume closed and try to do the same steps. If the composition opens then it's probably the media that causes this issue.
It would be good if you could repeat this making every file available at the original path one by one, and repeating the open procedures. This way you could find the file that casues the issue.
If you can find the one particular file, please upload it to the dropbox link I sent you in the PM.
