Can't Click
Can't Click
I've seen a solution mentioned before, But I can't seem to find it.
I'm running some background conversions right now and for some reason, when I go to the file browser inside Resolume, I try to click on a file, and it immediately un-selects what I clicked on, I can't even add things to the comp right now.
I thought I saw an option to turn off that fixes this, but I've slept since reading that.
Any help would be great.
Re: Can't Click
You are probably converting to that folder right?
The folder updates when you write to it and makes the list refresh, clearing your selection.
Re: Can't Click
Different folder, but same parent folder.
Example:
C:/content/new stuff
sub folders:
1
2
3
I'm converting in one, but trying to open something in 3
Re: Can't Click
Arvol wrote:I'm converting in one, but trying to open something in 3
If you have double clicked into folder 3, and so the others are not visible then the folder list should not refresh.
If you have just folded down folder 3 and you see folder 2 too then it may refresh.
Re: Can't Click
I've collapsed the folder in conversion but it still locks down the entire parent folder.
It's not a biggy, just something I've noticed.
Thankfully I only have another hour of conversions
Re: Can't Click
Try double clicking into your folder 3, you may succeed if you're fast enough.
We have a ticket for this constant refresh.
Re: Can't Click
Gotcha.
