Mask Mode issue
scottwestrick
Mask Mode issue
Post by scottwestrick »
When I use the One Below setting on a layer, it seems to mask everything EXCEPT the layer directly below. It worked fine before the most recent update, but now it seems to do the opposite of what is intended.
For example, I have a logo on layer 4. I select One Below on layer 4, and bring up the layer opacity. I have clips playing on layers 1-3. Layer 3 shows up full, unmasked. Layers 1 and 2 are masked by the logo on layer 4.
Anybody else having this issue?
reteet
Re: Mask Mode issue
Post by reteet »
happening on me aswell since 6.0.2
Re: Mask Mode issue
Layer masking in 6.0.2 is broken indeed, try disabling the masking clip's alpha channel until it's fixed in the next release.
Képernyőfotó 2017-12-16 - 12.47.33.png (4.2 KiB) Viewed 3441 times
