Text Animator won't save certain font styles
dig65
Post by dig65 »
Trying to use the Consola font with the Text Animator effect, here's what I see:
Setting the Style to "Regular" is not saved. Even just moving to another deck and back, the Style parm gets reset to "Bold". Setting Style to "Regular" and then saving the composition without switching decks, there is no Style parm saved in the XML. However, if you set the Style to "Bold Italic", that is properly saved (and a Style parm with value="Bold Italic" is saved in the composition XML). Switching Style to "Regular" after the "Bold Italic" value is saved just loses the Style parm again.
I'd like to use Consola Regular, but I can't.
Resolume Avenue 6.0.3
Re: Text Animator won't save certain font styles
Is that font a Windows built in font?
(#10556)
Ok, thanks.
I created a ticket.
