No Master Audio output in R 6.0.3
warpnote
Post by warpnote »
Hi Guys, I have trouble getting master audio output in R6.0.3
I'm setting up the primary sound driver to master out,
but all I get is silence.
If I set it to preview, the sound will work.
Is there a new master volume fader somewhere that I've missed?
Thanks, Warp
Re: No Master Audio output in R 6.0.3
There is a separate volume slider in the Composition panel. Enable Show Audio controls in the View menu to have it visible.
Do you have audio playing with a new composition?
A new composition will have this slider at max, so if you don't hear audio when playing, the issue lies somewhere else.
