DMX output does not calculate red value when using led fixtures with Amber.
VipsbKris
Post by VipsbKris »
I used this software for the first time in a live show Saturday, everything worked GREAT! ....EXCEPT
When trying to display red to all fixtures none of them that have Amber included into the calculations would output any red value until another color needed to be mixed into it, so trying to output just red nothing would output to the fixtures but it worked fine on all of the fixtures that were only RGBW. I confirmed this bug by altering the fixture profile to be simply RGBW and then made the Amber as a seperate channel and then eveything functioned as intended the rest of the night.
Re: DMX output does not calculate red value when using led fixtures with Amber.
Which Resolume version are you using?
VipsbKris
Post by VipsbKris »
I am using Arena 6
Works for me with all types of amber fixtures on my machine with 6.0.3.
Could you double check with Artnetominator, or Resolume's built in DMX monitor in Preferences that the red channels are indeed not sent out?
