to flash a clip button in APC40MK2 and RESOLUME6
lololum
Post by lololum »
Hello
Exuse me but I do not speak English but French, and I use google translation.
I did not find my answer or post that treated the subject neither in the forum nor in the help of resolume arena, can be because of my level of English :-(
I use RESOLUME ARENA 6 with an APC40MK2 ON MACBOOK PRO.
my question: can we make the clip release button blinks? I managed to put the colors that I want on my buttons but I do not understand how to make them blink as I throw them in the layer.
hoping you understand my problem.
Thank you for your answers.
Flaket
Re: to flash a clip button in APC40MK2 and RESOLUME6
Post by Flaket »
lololum wrote:Hello
Salut,
il y a un bugue pour l'instant dans la V6, ils sont sur le coup. Dans une prochaine update la couleur du bouton suivra l'etat du clip dans le layer.
Hy, There's a bug for the moment, They working on. In an update, the color of the button will follow the state of the clip in the layer.
lololum wrote: my question: can we make the clip release button blinks? I managed to put the colors that I want on my buttons but I do not understand how to make them blink as I throw them in the layer.
Would you only like to change the clips color when you drop it to a clip slot?
or would you like to have it blinking while the clip plays?
lololum
Post by lololum »
Flaket wrote:
lololum wrote:Hello
Salut,
Salut
Hello
Ok thank you for your answer
lololum
Post by lololum »
Hi and thank you for your reply
I would like to make it flash while the clip plays
