Insert clip between another clips not working
I think from 6.0.2 I have not working inserting clips =( that's very disappointing.
- Attachments
- R6.gif (100.07 KiB) Viewed 4554 times
Re: Insert clip between another clips not working
thanks for reporting this,
I created a ticket #10611
I'm on 6.0.3 and it works fine when I drag a clip from the [Files] browser within Arena but not if I drag an external file.
Elgarf, have you tried from the [Files] browser?
Oaktown, nope. I usually using Windows Explorer.
Dragging from [Files] panel works fine for me too, but it's comfortable for me using Windows Explorer (
yes it only happens dropping from Explorer / Finder.
