Envelope broke after saving comp
elgarf
Post by elgarf »
Hello. I made animation of parameter, but after saving-loading comp envelope brokes.
Good before saving
Bad after saving :?
I've attached sample comp.
Test.avc
(20.05 KiB) Downloaded 317 times
Re: Envelope broke after saving comp
Tested your comp and it's broken on my end as well. I fixed it and saved it but it's came back broken (different pattern). What's interesting is that the dot doesn't follow the line in the broken version!
If I switch from timeline to the other modes, and it seems to be fine. Then I went back to timeline and saved again and now it works! Check out the test_FOB.avc file I attached to this message
Test_FOB.avc
(19.62 KiB) Downloaded 313 times
elgarf
Post by elgarf »
Yep, It looks fixed, but looks like point still move not along a line.
Yeah, there seems to be a slight disconnect but I'm assuming the line is a estimated visual representation whereas the value is calculated on the fly.
Thanks,
it's happening when you set the parameter range to be really narrow.
I created ticket #10612.
elgarf
Post by elgarf »
Ok, thank you, Zoltán.
