Layer Order Issues
isaac_gray
Layer Order Issues
Post by isaac_gray »
In Arena 6, I have three output screens. My center Screen is mapped to layer 3. All three screens are mapped to layer 2.
If I play a video clip in layer 2 that plays across all three screens, but the attempt to override the center screen by playing a clip from layer 3 (which is above layer 2 and should play over top), the center screen still plays the content from layer 2 instead of layer 3. If I stop playing layer 2, it shows the video from layer 3 was playing behind the whole time.
My opacity is all the way up, I don't have any bypass checked in my layer 3, and my layer order should be correct. Why won't content play overt top of my multiscreen setup?
Re: Layer Order Issues
My guess is you're using layer to slice routing, and your slice order is the opposite of your layer order.
Joris wrote:My guess is you're using layer to slice routing, and your slice order is the opposite of your layer order.
That was my guess, Or he has multiple slices in ASS and they layer 3 slice is below the layer 2 slice
