bypass slices
rawdesigns
bypass slices
Post by rawdesigns »
Not sure if this is a bug or not but I remember in res5 in the advanced output window, if you select multiple slices, your "Input Opacity" and "Input Bypass/Solo" check boxes are present. But in res6 it looks like you have to do that individually on each slice. Not a big deal but just curious
Re: bypass slices
This is actually a bug. And you'll be pleased to know it has ticket number 10666 :evil:
Re: bypass slices
Oops. This is not actually a bug. We removed this option from multiselect, because this caused problems when the selection contained both slices with composition and routed inputs.
Ticket 10666 is related, but not the same.
dirtyjohn_lv
Re: bypass slices
Post by dirtyjohn_lv »
Is this fixed in 6.06? I have around 1500 slices i have to change the bypass option for :(
lightbx
Re: bypass slices
Post by lightbx »
What on GOD'S GREEN EARTH are you doing with 1500 SLICES? More information required for proper diagnosis!
dirtyjohn_lv
Re: bypass slices
Programming fun with chaser. It’s so hard to draw in every square to make things look random :roll:
3 virtual output to group my slices per screen, then 1 slice per screen in my main output to pull the virtual outputs.
If you add a group or layer , it resets the group in the input routing and end up have to uncheck every bypass again :cry:
drazkers
Re: bypass slices
Post by drazkers »
dirtyjohn_lv wrote:Programming fun with chaser. It’s so hard to draw in every square to make things look random :roll:
I had a similar issue in December with 1700 slices. My
Solution was to copy and paste after creating the right bypass settings.
I felt like I reported this awhile ago surprised its kicking around d.
Re: bypass slices
#9848 is the one where we made a change for the multi select, so composition slices can't be set to ignore opacity and bypass via multi select.
dirtyjohn_lv wrote:If you add a group or layer , it resets the group in the input routing and end up have to uncheck every bypass again :cry:
Adding a layer or a group should not have any effect on the Advanced output slice routings.
If you add a layer below a routed layer then the routed layer above will have the layer index increased, so of course you'll have to set that layer as input again.
In such a case then When I multi select my slices which have different settings for ignore bypass and opacity, and set the same type (layer) as input for them with a different layer, then my settings are kept. for the individual slices.
Selecting a group instead of a layer resets the ignore settings.
dirtyjohn_lv
Re: bypass slices
I'm kind of stuck then.
My original chaser output is from a completely different advanced output/composition setup. It's easy enough to copy/paste XML from one composition to another, but still have to change bypass setting because compositions/outputs don't match.
I could use drazkers method, but I would essentially have to recreate the whole chaser again. Either way, lots of lost time
